Community Member
Strange behavior ( BGP and OSPF)
I have 3 routers - 2610,1601 and 1603.
In route table i see strange things -same routes marked as B and as O. BGP route have AD 200
and OSPF route have AD is 110. But by default, a lower AD is always prefered.
Why it's so?
-----------2610-----------
2610#sh ip int brief
Ethernet0/0 A.B.C.1 YES NVRAM up up
Serial0/0 unassigned YES TFTP up up
Serial0/0.2 192.168.100.1 YES NVRAM up up
Serial0/0.3 unassigned YES unset up up
Loopback0 192.168.17.1 YES manual up up
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
router bgp 333
no synchronization
bgp log-neighbor-changes
network 192.168.17.0
network A.B.C.0
neighbor 192.168.100.2 remote-as 333
neighbor 192.168.100.2 route-reflector-client
neighbor A.B.C.111 remote-as 333
neighbor A.B.C.111 route-reflector-client
2610#sh ip route bgp
192.168.21.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.21.0/24 [200/0] via 192.168.100.2, 00:02:43
192.168.16.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.16.0/24 [200/0] via A.B.C.111, 00:02:43
2610#sh ip route ospf
O 192.168.21.1/32 [110/782] via 192.168.100.2, 00:03:39, Serial0/0.2
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
O 192.168.20.1/32 [110/11] via A.B.C.111, 00:03:39, Ethernet0/0
O 192.168.16.1/32 [110/11] via A.B.C.111, 00:03:39, Ethernet0/0
192.168.1.0/30 is subnetted, 1 subnets
O 192.168.1.76 [110/2343] via 192.168.100.2, 00:03:39, Serial0/0.2
-----------1603-----------
c1603#sh ip int brief
Ethernet0 A.B.C.111 YES NVRAM up up
Loopback0 192.168.20.1 YES manual up up
Loopback1 unassigned YES manual up up
Loopback2 unassigned YES manual up up
Loopback3 192.168.16.1 YES manual up up
router ospf 1
router bgp 333
no synchronization
network 192.168.16.0
network 192.168.20.0
network A.B.C.0
neighbor A.B.C.1 remote-as 333
c1603#sh ip route ospf
B.C.D..0/29 is subnetted, 1 subnets
O B.C.D..200 [110/801] via A.B.C.1, 00:03:58, Ethernet0
O 192.168.10.0/24 [110/801] via A.B.C.1, 00:03:58, Ethernet0
O 192.168.11.0/24 [110/20] via A.B.C.1, 00:03:58, Ethernet0
O 192.168.21.1/32 [110/792] via A.B.C.1, 00:03:58, Ethernet0
192.168.17.0/24 is variably subnetted, 2 subnets, 2 masks
O 192.168.17.1/32 [110/11] via A.B.C.1, 00:03:58, Ethernet0
O 192.168.1.76 [110/2353] via A.B.C.1, 00:03:58, Ethernet0
O 192.168.100.0/24 [110/791] via A.B.C.1, 00:03:58, Ethernet0
c1603#sh ip route bgp
B 192.168.21.0/24 [200/0] via 192.168.100.2, 00:03:17
B 192.168.17.0/24 [200/0] via A.B.C.1, 00:03:11
---------------1601--------
Cisco1601#sh ip int brief
Ethernet0 B.C.D..202 YES NVRAM up up
Loopback0 192.168.21.1 YES manual up up
Serial0 unassigned YES NVRAM up up
Serial0.1 192.168.1.77 YES NVRAM up up
Serial1 unassigned YES NVRAM up up
Serial1.1 192.168.100.2 YES NVRAM up up
router ospf 1
router bgp 333
no synchronization
network 192.168.21.0
network B.C.D..200 mask 255.255.255.248
neighbor 192.168.100.1 remote-as 333
Cisco1601#sh ip route bgp
B 192.168.20.0/24 [200/0] via A.B.C.111, 00:03:33
B 192.168.17.0/24 [200/0] via 192.168.100.1, 00:03:28
B 192.168.16.0/24 [200/0] via A.B.C.111, 00:03:33
Cisco1601#sh ip route ospf
O 192.168.20.1/32 [110/1573] via 192.168.100.1, 00:04:41, Serial1.1
O 192.168.17.1/32 [110/1563] via 192.168.100.1, 00:04:41, Serial1.1
O 192.168.16.1/32 [110/1573] via 192.168.100.1, 00:04:41, Serial1.1
Gold
Re: Strange behavior ( BGP and OSPF)
I don't see any conflict between the ospf and bgp routes in the output you've provided? You seem to have:
192.168.20.0/24 via bgp
192.168.20.1/32 via ospf
192.168.17.0/24 via bgp
192.168.17.1/32 via ospf
192.168.16.0/24 via bgp
192.168.16.1/32 via ospf
In each case, you have a /24 via bgp, and a /32 via ospf. These overlap, but they are not identical--they are each a seperate route--so ospf's and bgp's routing information don't ever get compared based on admin distance.
Russ.W
Community Member
Well, but who to made that i have only one route /24 and can you help me to understand what means
network 0.0.0.0 255.255.255.255 area ?
Gold
I don't understand the question about the /24's? The network 0.0.0.0 255.255.255.255 area 0 statement tells ospf to find all the interfaces on this box within the address range 0.0.0.0 with all bits wildcard, and run ospf on those interfaces. In this case, that's all interfaces.
Russ.W
102
