Strange BGP message + high CPU load
Since 2 weeks I see strange BGP message and peaks of CPU load of 95%
for BGP Scanner process every 2 hour.
May 30 14:59:18 CEST: BGP(0): For aggregate 195.35.128.0/17
May 30 14:59:18 CEST: BGP(0): 195.35.128.0/17 subtree has an entry 195.35.128.0/17
May 30 14:59:18 CEST: BGP(0): 195.35.128.0/17 subtree has an try 195.36.0.0/18
May 30 14:59:18 CEST: BGP(0): Need not be re-aggregated
May 30 14:59:18 CEST: BGP(0): For aggregate 195.85.128.0/18
May 30 14:59:18 CEST: BGP(0): 195.85.128.0/18 subtree has an entry 195.85.128.0/18
May 30 14:59:18 CEST: BGP(0): 195.85.128.0/18 subtree has an try 195.86.0.0/16
May 30 14:59:18 CEST: BGP: 195.85.155.97 rcv message type 4, length (excl. header) 0
May 30 14:59:20 CEST: BGP(0): Aggregate processing for IPv4 Unicast
Any ideas ?
Thanks in advance,
E. Tantsura
Re: Strange BGP message + high CPU load
Hello E.
Check Link flapping, or around LAN spanning tree change...;
BGP is consuming a lot CPU cycle during Table calculation, and doesn't like
topologie change (router running BGP too).
Can check also, Buffer lack (sh inter, check for in or out drop).
Can check also your config regarding Loops. I don't like "need not be re-aggregated". doesn't look clean and can generate burden
Anyway this look like network instability.
hope this help
Regards Patrick
Gold
Do a show debug and see what it says. These messages indicate that the BGP scanner is doing what it is supposed to do, but the proc util does sound a bit high. Are you running full internet routing tables? From how many peers? Turning off the debug that's spitting the message out may reduce your proc util to a reasonable level.
Russ
Hi Russ,
Thanks a lot.
I'm running full internet routing tables but it's not a problem,
the router is 7507 with 256 Mb RAM.
The strange thing is that cpu load peaks(BGP scanner process) are every 2 hours, but not beetwen 12 and 6 am and it began 3 weeks ago.
I didn't upgrade IOS or something like this....
386
