Webcast-Catalyst9k
Strange high CPU utilization w/o processes that makes cpu load
Greetings,
Strange thing happend with our 7206VXR. It starts to utilize 40% CPU but there is no processes which loads cpu. Total router's throughput comes short of satisfactory.
router#sh processes cpu sorted
CPU utilization for five seconds: 40%/32%; one minute: 36%; five minutes: 36%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
39 504392 886343 569 6.96% 5.63% 5.42% 0 IP Input
66 3488 1164 2996 0.65% 0.05% 0.01% 3 SSH Process
136 1668 272 6132 0.40% 0.04% 0.00% 0 BGP Scanner
61 7780 6004 1295 0.24% 0.14% 0.09% 0 CEF process
5 56 304 184 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
Experimentally, I've found that CPU load become 6-7% when I shutdown interface Serial2/5 (our link to provider, bandwidth 2Mbit/s).
What can be cause of this strange behavior?
How can I fix this?
Thanks in advance.
Best regards,
Dmitry N. Hramtsov
Part of my config:
interface Serial2/5
description Leased line to Provider
bandwidth 2048
ip address x.y.189.130 255.255.255.252
ip access-group 113 in
ip access-group 104 out
ip nat outside
rate-limit input access-group 117 1000000 1500 2000 conform-action transmit exceed-action drop
ip route-cache flow
no ip mroute-cache
serial restart-delay 0
no cdp enable
end
access-list 113 deny udp any any eq 1434
access-list 113 deny ip 10.0.0.0 0.255.255.255 any
access-list 113 deny ip 172.16.0.0 0.15.255.255 any
access-list 113 deny ip 192.168.0.0 0.0.255.255 any
access-list 113 deny ip any 10.0.0.0 0.255.255.255
access-list 113 deny ip any 172.16.0.0 0.15.255.255
access-list 113 deny ip any 192.168.0.0 0.0.255.255
access-list 113 deny udp any any eq 135
access-list 113 deny udp any any eq netbios-ns
access-list 113 deny udp any any eq netbios-dgm
access-list 113 deny udp any any eq netbios-ss
access-list 113 deny udp any any eq 445
access-list 113 deny tcp any any eq 135
access-list 113 deny tcp any any eq 137
access-list 113 deny tcp any any eq 138
access-list 113 deny tcp any any eq 139
access-list 113 deny tcp any any eq 445
access-list 113 permit ip any any
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip any 10.0.0.0 0.255.255.255
access-list 104 deny ip any 172.16.0.0 0.15.255.255
access-list 104 deny ip any 192.168.0.0 0.0.255.255
access-list 104 deny udp any any eq 135
access-list 104 deny udp any any eq netbios-ns
access-list 104 deny udp any any eq netbios-dgm
access-list 104 deny udp any any eq netbios-ss
access-list 104 deny udp any any eq 445
access-list 104 deny tcp any any eq 135
access-list 104 deny tcp any any eq 137
access-list 104 deny tcp any any eq 138
totally 174 lines in access-list 104
access-list 104 deny ip x.y.218.160 0.0.0.31 any
access-list 104 deny ip x.y.214.96 0.0.0.31 any
access-list 104 deny ip x.y.221.96 0.0.0.31 any
access-list 104 deny ip x.y.221.128 0.0.0.31 any
access-list 104 deny ip x.y.222.64 0.0.0.31 any
access-list 104 permit ip any any
access-list 117 deny ip any x.y.164.0 0.0.0.255
access-list 117 deny ip any host x.y.209.65
access-list 117 permit ip any any
1 ACCEPTED SOLUTION
Gold
Re: Strange high CPU utilization w/o processes that makes cpu lo
The configs I see have the blocking on the outbound side of the serial interface? Which would mean they are switched then dropped, driving up CPU util on the interrupt path....
Russ.W
Can u modify your ACL 113 & 104.
Mearge both in to one ACL.or try route-map policy.
How about the link utilization on your service provide link?
Gold
Note your CPU utilization is:
Which means the total utilization is 40%, but the interrupt context utilization is 32%. You shouldn't expect the total of your processes to be taking up more than 8%. When interrupt context is high, like this, it's generally one of two or three things. First, run a show alignment, and see what the numbers are there. If they are high, and increase rapidly in either the misalignments or the spurious accesses, then you might have some sort of a problem that needs to be looked at on the router.
If these numbers are low, or are not increasing, then it's probably just switching time through the box. You say this is a serial link--what sort of bandwidth is it? As the first poster noted, the access list coul dbe causing your processor to spend a lot of time in switching packets.
I'd first switch to a named access list. Second, I'd try to simplify the access list as much as possible. Cut out as many lines as possible, by merging lines, dropping lines, etc. Third, I'd make certain the access list is arranged so the most likely drop is highest in the list, if possible.
Russ.W
Thanks for a quick response.
I've read "Troubleshooting High CPU Utilization on Cisco Routers" (http://www.cisco.com/warp/public/63/highcpu.html) and found that I have 32% cpu load in interrupts (just as you say). There are a few reasons for that, so I've tested all of them:
- Voice/ATM ports - I have no such equipment;
- Inappropriate switching path - I have "ip route-cache flow" for each interfaces;
- Memory alignment corrections - "show align" prints that no alignment data has been recorded;
- The router is overloaded with traffic - I don't think so: Se2/5 - in/out 2Mbit/2Mbit, Fa0/0 - in/out 6Mbit/4Mbit;
But, "show interface Fast0/0" displays a lot of flushes:
router#show interface Fast0/0
FastEthernet0/0 is up, line protocol is up
Description: Main Interface - Connected to N1C2P10
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 8/255, rxload 14/255
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:14:28
Input queue: 21/255/0/269 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 5792000 bits/sec, 3838 packets/sec
5 minute output rate 3410000 bits/sec, 879 packets/sec
AFAIK, throttles indicate that the router is overloaded with traffic. I do not understand, how 6Mbit/s can overload 7200 (with a flow cache)?
Next about ACLs. It is a good idea to simplify access-list 104. I'll try to test this. Btw, is there any way to check "how expensive ACL is?"?
(Just like in calatyst I can check if my ACL fit in NIC)
Thanks in advance.
Best regards,
Dmitry N. Hramtsov
Gold
It's good that you aren't recording alignment errors....
Flushes aren't exactly the same thing as throttles. Throttles occur at the interrupt level, while flushes are typically only for the input queue, which is process switched traffic. That might indicate that you are getting a lot of process switched traffic off this interface (though I'd think you're process level would be higher out of the total percentage if this is true). I'd check show ip cef not-cef-switched to see what cef thinks about the amount of traffic that's being punted up to the process level. I'd expect not more than perhaps 1% to 5% of the traffic to be punted, most likely. You could be punting a lot more traffic, and then dumping it right at ip input, so it's not showing up as a lot of processing time there, but it is showing up as a lot of processing time under the interrupt context.
On the other hand, 269 flushes out of 3838 packets/second inbound, sustained, doesn't seem like a lot of flushes to me. :-)
To be more precise: A throttle occurs when a packet is received by the router, and the buffer the packet is placed in on the interface's receive ring cannot be replaced. Another reason an interface may throttle is because the number of interrupts being processed is "too high," but "too high" is defined per interface, platform type, changes based on various configurations, etc. A flush occurs when the number of packets sitting in input queues assigned to this interface exceeds the input queue counter, and some higher priority packets are received (generally control traffic). When this occurs, SPD will flush the lower priority traffic.
Inside Cisco IOS Software covers throttles pretty good, and it's still available on Amazon (it's out of print, and we're working on a new edition, theoretically, or we're supposed to be). SPD, and flushes, can be found here:
http://www.cisco.com/en/US/products/hw/routers/ps167/products_tech_note09186a008012fb87.shtml
You are also running netflow, but are you pulling the netflow stats? Theoretically, netflow will speed up access list processing, but since netflow was put into CEF, I'm not certain how true that it any longer. If you're not pulling the stats, try turning netflow off and see if the util goes up or down.
There's no way to know what impact a given access list is having on packet switching times. Whether or not a given access list fits into hardware on the cats, and on the 12000, makes a huge difference in their performance. The length of an access list, however, on a software switched platform, like the 7200, is more incremental, or slowly degrading, so it's harder to judge. Named access lists are structured differently than numbered access lists, so they might be faster in this case. It's hard to tell, but I usually find them less processor intensive, myself.
Hope that helps. Sorry it took me so long to answer this time--this thread isn't passing my email subscription filter. :-( I'll try to watch it specifically for the next couple of days, or you can put some routing protocol name in the next response to make certain it passes my filters. :-)
Russ.W
Hi Russel
i m facing same probs with one of my router , i have pasted the sh alig command output too.pls advice wht to do now .ACLs r in place.using both ACLs/route map...y i m getting this ?whts the meaning of this ...pls help
Cbe#sh alignment
Total Spurious Accesses 1, Recorded 1
Address Count Traceback
48 1 0x803DB2DC 0x801EF158 0x8019BCF4 0x80029744
Cbe#
regds
prem
Gold
A spurious access means a piece of code has tried to access some memory location it shouldn't. Normally, this is the result of a program trying to read a pointer to a data structure that is null.... I would need the code version (the output of show version) to decode this one--spurious accesses should always be filed as defects, so if you access to the TAC, you should go through them and get a case opened, and then check to see if this is a known problem, or something new that should be filed.
Other than this, the number of spurious accesses you are seeing here--48--isn't going to be enough to impact your CPU utilization. Generally, they have to be in the tens of thousands, or more, to cause a problem with the CPU. So, you're probably seeing CPU slowdown for some other reason than just these, as well, if you're seeing a CPU slowdown.
Russ.W
Hello Russ,
Sorry for a bit delay, I was waiting for weekend to begin tests.
Ok. I've discovered that cpu load isn't depend on:
- my long ACLs
I've removed access list 104 and cpu utilization still was ~40%
- flow route cache
I've disabled netflow:
router(config)#no ip flow-cache feature-accelerate
router(config)#no ip flow-export destination
router(config)#interface FastEthernet 0/0
router(config-if)#no ip route-cache flow
. . etc . .
Here is some statistics you asking about:
Unfortunatelly "sh ip cef not-cef-switched" doesn't work for me:
router#sh ip cef not-cef-switched
% Invalid input detected at '^' marker.
router#sh ip cef summary
IP CEF with switching (Table Version 4521), flags=0x0
511 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 28
511 leaves, 52 nodes, 115400 bytes, 4612 inserts, 4101 invalidations
0 load sharing elements, 0 bytes, 0 references
universal per-destination load sharing algorithm, id 7FBC815A
3(0) CEF resets, 0 revisions of existing leaves
Resolution Timer: Exponential (currently 1s, peak 1s)
0 in-place/0 aborted modifications
refcounts: 14537 leaf, 13568 node
Adjacency Table has 304 adjacencies
router#sh interfaces FastEthernet 0/0 stats
FastEthernet0/0
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 271075 22852461 98978 12053654
Route cache 4073578 738791081 886052 438803773
Total 4344653 761643542 985030 450857427
router#sh interfaces Serial 2/5 stats
Serial2/5
Processor 46688 6148235 93280 6139603
Route cache 377961 221844361 427844 252853347
Total 424649 227992596 521124 258992950
I.e. route cache works efficiently enough.
router#sh ip cache flow
IP packet size distribution (5424636 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.001 .168 .708 .012 .009 .003 .001 .001 .001 .001 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .000 .010 .007 .067 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 6553988 bytes
64750 active, 786 inactive, 3995921 added
4057309 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
last clearing of statistics 00:23:48
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 99 0.0 15 633 1.1 3.0 17.3
TCP-FTP 1677 1.1 5 64 6.0 8.0 15.2
TCP-FTPD 477 0.3 48 865 16.2 36.2 10.8
TCP-WWW 48512 34.1 10 560 373.4 10.1 15.0
TCP-SMTP 10776 7.5 8 282 66.2 5.4 15.9
TCP-X 6 0.0 3 44 0.0 2.8 16.3
TCP-BGP 39 0.0 1 49 0.0 0.0 19.0
TCP-NNTP 170 0.1 100 711 11.9 34.2 10.4
TCP-Frag 1 0.0 1 40 0.0 0.0 18.6
TCP-other 164938 116.1 4 376 571.7 3.4 17.8
UDP-DNS 33991 23.9 3 87 81.9 2.2 18.4
UDP-NTP 173 0.1 1 76 0.1 0.2 18.9
UDP-TFTP 1 0.0 1 48 0.0 0.0 20.8
UDP-Frag 1 0.0 6 1481 0.0 0.0 21.0
UDP-other 42910 30.2 2 127 65.2 0.4 18.9
ICMP 3755973 2645.0 1 91 2648.3 0.0 18.9
IPINIP 19 0.0 1 112 0.0 1.7 19.6
GRE 36 0.0 773 123 19.6 69.6 0.2
Total: 4059799 2859.0 1 188 3862.2 0.3 18.8
On the one hand, I have many active flows and many new flows per second.
Is it possible that CPU utilized by creating "new flows memory structures" and by removing "old structures"?
On the other hand, when netflow is disabled CPU utilization still serious.
router#sh ip flow export
Flow export v5 is enabled for main cache
Exporting flows to x.y.164.4 (2055)
Exporting using source interface Loopback0
Version 5 flow records, origin-as
5070727 flows exported in 169025 udp datagrams
0 flows failed due to lack of export packet
1 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
Thanks in advance.
Best regards,
Dmitry N. Hramtsov
P.S. Routing protocols for your filter: RIP OSPF BGP IGRP EIGRP ISIS :)
Gold
If turning netflow off, and turning the access list off, don't improve the cpu utilization, then we need to think about this a bit more.... The command we're looking for is actually chow cef not-cef-switched--try that and post the results. It could just be that the router really is this busy with this much traffic--I don't have any real way to load up a 7200 with this much traffic in the lab, but if the output of show cef not looks normal, as everything else has, then I'll need to talk to one of the other guys on the RP Scaling team about trying to get one of the traffic generators on line to set something up, or some folks on the 72 team, who should be able to tell me if these numbers look normal.
Thanks for the rp's--they worked. Though I work on CEF and architecture stuff a good bit, I don't normally monitor these forums for those sorts of questions, just routing stuff, which is why I filter the postings. :-)
Russ.W
Gold
FastEthernet0/0
Switching path Pkts In Pkts Out
Processor 271075 98978
Route cache 4073578 886052
Serial2/5
Processor 46688 93280
Route cache 377961 427844
By the way, the reason I want show cef not is because of this--I'm certain this command doesn't know the difference between cef and fast switched. You actually shouldn't have _any_ fast switched traffic on this box, but I want to make certain of that before I ask the 72 and cef guys.
Second, I would probably expect about a 100 to 1 ratio on cef to process switched packets, if not higher. Your ratios look low to me--the serial interface is process switching about 1 packet out of every 8, and your fast/e is process switching about 1 packet out of every 15 or so. Hmmm.... I just don't know if I trust those numbers, really, and I would think they would be higher, somehow, unless the traffic levels are low enough for the control traffic to skew them (for instance, in my lab, the process switched traffic is higher than the cef switched traffic).
Russ.W
Thank you for your quick and useful responses.
Here is a "show cef ..." results:
router#show cef not-cef-switched
CEF Packets passed on to next switching layer
Slot No_adj No_encap Unsupp'ted Redirect Receive Options Access Frag
RP 143104 0 0 86607 1075281 0 0 0
router#show cef drop
CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 1876674 465 0 34939 0 14
router#sh cef interface FastEthernet 0/0
FastEthernet0/0 is up (if_number 3)
Corresponding hwidb fast_if_number 24
Corresponding hwidb firstsw->if_number 3
Internet Protocol processing disabled
Hardware idb is FastEthernet0/0
Fast switching type 1, interface type 18
IP CEF switching enabled
IP Flow switching turbo vector
IP Flow CEF switching turbo vector
Input fast flags 0x43, Output fast flags 0x101
ifindex 1(1)
Slot 0 Slot unit 0 VC -1
Transmit limit accumulator 0x0 (0x0)
IP MTU 1500
router#sh cef interface Serial 2/5
Serial2/5 is up (if_number 10)
Corresponding hwidb fast_if_number 10
Corresponding hwidb firstsw->if_number 10
Internet address is x.y.z.130/30
ICMP redirects are always sent
Per packet load-sharing is disabled
IP unicast RPF check is disabled
Inbound access list is 113
Outbound access list is 104
IP policy routing is disabled
Interface is marked as point to point interface
Hardware idb is Serial2/5
Fast switching type 4, interface type 63
IP CEF switching disabled
IP Null turbo vector
Input fast flags 0x45, Output fast flags 0x101
ifindex 8(8)
Slot 2 Slot unit 5 VC -1
IP MTU 1500
As you saw in my previous post, most of flows I have is ICMP.
I discovered, that this is worms/viruses activity in our networks. Most of our computers are firewalled on that 7200 (so no traffic goes to Se2/5 and further), but anyway flows are created.
I've firewalled that traffic on a L3 switch below 7200, and 7200's CPU load dramatically decreased. You may see this on mrtg cpu load graph ( http://aurora.nsu.ru/hdn/c7206vxr_cpu-day.png ), time: 19-20 o'clock.
This is my current stats:
router#sh processes | i CPU
CPU utilization for five seconds: 17%/12%; one minute: 18%; five minutes: 17%
IP packet size distribution (462526 total packets):
.005 .468 .155 .038 .025 .012 .005 .003 .003 .004 .002 .002 .002 .002 .002
.002 .002 .014 .029 .215 .000 .000 .000 .000 .000 .000
7308 active, 58228 inactive, 100012 added
294780 ager polls, 0 flow alloc failures
last clearing of statistics 00:04:50
TCP-Telnet 19 0.0 5 294 0.3 4.4 11.9
TCP-FTP 223 0.7 7 71 5.6 7.5 11.6
TCP-FTPD 40 0.1 41 909 5.7 9.8 8.7
TCP-WWW 13007 44.8 9 601 434.6 8.9 9.6
TCP-SMTP 2839 9.7 9 223 88.1 5.4 9.3
TCP-BGP 10 0.0 1 49 0.0 0.0 18.6
TCP-NNTP 102 0.3 65 862 23.1 34.1 9.1
TCP-other 33796 116.5 6 430 716.1 4.5 16.6
UDP-DNS 7772 26.8 3 80 99.3 1.8 18.5
UDP-NTP 54 0.1 1 76 0.1 0.0 18.5
UDP-other 6174 21.2 3 219 73.9 0.7 18.6
ICMP 35411 122.1 1 91 124.9 0.0 18.8
IPINIP 4 0.0 2 83 0.0 0.5 19.3
GRE 27 0.0 441 284 41.1 48.0 4.7
Total: 99478 343.0 4 410 1613.5 3.1 16.5
So, what was(is?) the bottleneck? ICMP protocol? Many new flows? Something else?
And why then I shutdown Se2/5 CPU utilization goes to 1-2%? (but parasitical flows are still created)
Thanks in advance.
Best regards,
Dmitry N. Hramtsov
Gold
It;s just the traffic load itself, from the virus infected machines. With the serial interface down, these packets aren't being switched, they are just being dropped at the inbound interface.
Russ.W
Yes, but that packets are dropped anyway by incoming ACL on one of FastEth0/0 subinterface. It does not depend on Se2/5 status. Packets from most part of our network are dropped.
Gold
Russ.W
Yes, it looks like you are absolutely right. Thank you for your assistance.
Best regards,
Dmitry N. Hramtsov
I forget to add "sh in fa 0/0" to my previous post:
router#sh in fa 0/0
Hardware is DEC21140A, address is 0001.6369.e800 (bia 0001.6369.e800)
reliability 255/255, txload 6/255, rxload 8/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last clearing of "show interface" counters 1d01h
Input queue: 1/255/18278/125737 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 3417000 bits/sec, 1003 packets/sec
5 minute output rate 2493000 bits/sec, 820 packets/sec
164917387 packets input, 3312364739 bytes
Received 2422195 broadcasts, 0 runts, 2 giants, 1827 throttles
5974 input errors, 0 CRC, 0 frame, 0 overrun, 5970 ignored
0 watchdog
92712980 packets output, 1711179583 bytes, 0 underruns
0 lost carrier, 0 no carrier
As you see, input packets/sec is now 4 times lower.
Just like CPU usage. It is very strange.
Best regards,
Dmitry N. Hramtsov
376
