Strange Issue preventing upgrade from IOS 12.2 to 12.3 on 3640
mhcraig
I've got 2 IDENTICAL (hardware, memory, etc) 3640's with the exeception of their ROM bootstraps:
3640 #1 ROM: System Bootstrap, Version 11.1(20)AA2
3640 #2 ROM: System Bootstrap, Version 11.1(19)AA
They both have 128MB/32MB
I cannot get the older rom version router to load a 12.3 image. I get this error when I try to force boot with the 12.3(3) image:
rommon 5 > boot flash flash:c3640-io3-mz.123-3.bin
program load complete, entry point: 0x80008000, size: 0x62a0dc
Self decompressing the image : ############################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000D8 0X00178610 Dual Fast Ethernet Combo Port Module, 2 WAN
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X005F57D0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 6Mb.
Using 4 percent iomem. [6Mb/128Mb]
I've tried allocating more iomem just to see what would happen - no luck. Both routers have plenty of ram to handle the image. After failing to boot from the c3640-io3-mz.123-3.bin, it falls back to the 12.2 image also in flash.
I've seen some threads that indicate a newer bootstrap version might help (referenced some bugs in 11.1(19)AA ). If so, how do I go about upgrading/updating the system bootstrap. I have never done that before.
Thanks in advance,
Hutch
igorj
Hello Hutch,
Have you tried to boot the router without any
modules (NM) installed? Are there any recently installed parts in it?
Here's the scenario for bootstrap upgrade:
http://www.cisco.com/warp/public/130/rommon_boot_image.html
/Igor
Igor-
Thanks for the link.
No I have not tried to boot without the 4 modules in it - good idea. I'll try it out and let you know.
Thanks again,
Hutch
There haven't been any new modules/parts put it in.
I just tried booting without the 2 modules (there aren't 4 like I said in my previous post) in it. Same basic results - it tries, then backs down to the 12.2 image also on flash (Version 12.2(13a):
rommon 1 > boot flash flash:c3640-io3-mz.123-3.bin
ID MEMORY_REQ TYPE
TOTAL: 0X00304BB0
Rounded IOMEM up to: 4Mb.
Using 3 percent iomem. [4Mb/128Mb]
I'll see if that link provides any insight.
Thanks again,
Hutch
I think I've answered my own question - at least regarding updating the rom boot image. It's just a physical chip that can be purchased and installed to update to Version 11.1(20)AA2.
Cisco Part #: BOOT-3600
I'll buy the upgrade and see if that does the trick....
Hutch
