Community Member
Strange output
2950# sh spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 24577
Address 000b.5f84.3140
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 24577 (priority 24576 sys-id-ext 1)
Aging Time 300
Interface Port ID Designated Port ID
Name Prio.Nbr Cost Sts Cost Bridge ID Prio.Nbr
Fa0/2 128.2 19 FWD 0 24577 000b.5f84.3140 128.2
Fa0/4 128.4 19 FWD 0 24577 000b.5f84.3140 128.4
Fa0/5 128.5 100 FWD 0 24577 000b.5f84.3140 128.5
Fa0/6 128.6 100 FWD 0 24577 000b.5f84.3140 128.6
Fa0/7 128.7 19 FWD 0 24577 000b.5f84.3140 128.7
Fa0/8 128.8 19 FWD 0 24577 000b.5f84.3140 128.8
Fa0/9 128.9 19 FWD 0 24577 000b.5f84.3140 128.9
Fa0/10 128.10 19 FWD 0 24577 000b.5f84.3140 128.10
Fa0/11 128.11 19 FWD 0 24577 000b.5f84.3140 128.11
Fa0/13 128.13 19 FWD 0 24577 000b.5f84.3140 128.13
Fa0/14 128.14 19 FWD 0 24577 000b.5f84.3140 128.14
Fa0/15 128.15 19 FWD 0 24577 000b.5f84.3140 128.15
Fa0/16 128.16 19 FWD 0 24577 000b.5f84.3140 128.16
Fa0/17 128.17 19 FWD 0 24577 000b.5f84.3140 128.17
Fa0/18 128.18 19 FWD 0 24577 000b.5f84.3140 128.18
Fa0/19 128.19 100 FWD 0 24577 000b.5f84.3140 128.19
Fa0/20 128.20 19 FWD 0 24577 000b.5f84.3140 128.20
Fa0/22 128.22 19 FWD 0 24577 000b.5f84.3140 128.22
Fa0/23 128.23 19 FWD 0 24577 000b.5f84.3140 128.23
Fa0/24 128.24 19 FWD 0 24577 000b.5f84.3140 128.24
Gi0/1 128.25 4 FWD 0 24577 000b.5f84.3140 128.25
Gi0/2 128.26 4 FWD 0 24577 000b.5f84.3140 128.26
VLAN0002
Root ID Priority 32770
Bridge ID Priority 32770 (priority 32768 sys-id-ext 2)
Aging Time 300
Fa0/5 128.5 100 FWD 0 32770 000b.5f84.3140 128.5
Fa0/21 128.21 19 FWD 0 32770 000b.5f84.3140 128.21
Gi0/1 128.25 4 FWD 0 32770 000b.5f84.3140 128.25
VLAN0003
Root ID Priority 32771
Bridge ID Priority 32771 (priority 32768 sys-id-ext 3)
Aging Time 300
Fa0/5 128.5 100 FWD 0 32771 000b.5f84.3140 128.5
Gi0/1 128.25 4 FWD 0 32771 000b.5f84.3140 128.25
2950# sh vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10
Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/17, Fa0/18
Fa0/19, Fa0/20, Fa0/22, Fa0/23, Fa0/24, Gi0/2
2 INTERNET active Fa0/21
3 Out active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
Port fa0/5 belongs to 2 VLAN ( VLAN2,3)- it's from #sh spanning-tree. But from #sh vlan I can see that VLAN 3 is empty and only fa0/21 belongs to VLAN 2.
Why it's so?
Re: Strange output
is fa0/5 a trunk port? can you paste the relevant config for fa 0/5
Community Member
Re: Strange output
#sh int fa0/5 sw
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Protected: false
Voice VLAN: none (Inactive)
Appliance trust: none
#sh int fa0/5 tr
Port Mode Encapsulation Status Native vlan
Fa0/5 desirable 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/5 1-4094
Port Vlans allowed and active in management domain
Fa0/5 1-3
Port Vlans in spanning tree forwarding state and not pruned
Fa0/5 1-3
Community Member
Re: Strange output
yes, i understand-it's trunked port! Thank's !
Re: Strange output
What you are seeing is normal on a trunked port
Community Member
Re: Strange output
Is fa0/5 in trunking mode?
( show trunk )
Your port belongs to many Vlans.
If yes, it's not strange.
It's a normal behaviour.
86
