07-31-2003 06:54 PM - edited 03-02-2019 09:17 AM
This message is linecard fail,but we plug the line card to another cat6500 is normal.
SYNDIAGS:Syndiags failed on Module #4. Use 'show test 4'
to see results of tests.
Module 4 : 8-port 1000BaseX Ethernet
Line Card Firmware Status for Module 4 : PASS
Port Status :
Ports 1 2 3 4 5 6 7 8
GBIC Status :
N N N N N N N N
Line Card Diag Status for Module 4 (. = Pass, F = Fail, N = N/A)
Loopback Status [Reported by Module 1] :
F F F F F F F F
07-31-2003 09:14 PM
Check to see if the card is seating properly. Check for any bent pins in the backplane
07-31-2003 09:54 PM
Thanks your help
We check for any bent pins in the backplane then found bent pins in module 3. Now our cat6500 is normal
