Webcast-Catalyst9k
Strange Problem Cat6500
This message is linecard fail,but we plug the line card to another cat6500 is normal.
SYNDIAGS:Syndiags failed on Module #4. Use 'show test 4'
to see results of tests.
Module 4 : 8-port 1000BaseX Ethernet
Line Card Firmware Status for Module 4 : PASS
Port Status :
Ports 1 2 3 4 5 6 7 8
GBIC Status :
N N N N N N N N
Line Card Diag Status for Module 4 (. = Pass, F = Fail, N = N/A)
Loopback Status [Reported by Module 1] :
F F F F F F F F
Re: Strange Problem Cat6500
Check to see if the card is seating properly. Check for any bent pins in the backplane
Thanks your help
We check for any bent pins in the backplane then found bent pins in module 3. Now our cat6500 is normal
132
