Strange problem in 837 router
I have the 837 ADSL router connect to the ISP via boardband. I use the wizard to setup the router.
I can access the web and download .exe file. However the download file cannot be execute or if it is a zip. file, it cannot be extract.
I switch to 827 ADSL and it work fine.
Any similar issue out there??
1 REPLY
Bronze
Re: Strange problem in 837 router
The problem is indeed strange. I have not come across such a problem. But, you can probably check the size of the downloaded file using both the devices and see if it gives you any clue. Another thing that you can try is use a different image on the 837 and try downloading the files.
83
