04-04-2004 12:59 AM - edited 03-02-2019 02:46 PM
we are facing a strange problem, if our IPLC link goes down, even then sometimes on the router serial interface, the link protocol is shown as "UP", we have a multiping utility and the modem both show as "Down", but sometimes the router reports as "Up", any suggestions???
-Sai.
04-09-2004 06:58 AM
Have you set the keepalives? This is sometimes the case when keepalives are turned off.
04-12-2004 11:49 PM
Can you tell me how to set the keepalives??
-Sai.
04-13-2004 05:40 AM
Sai, keepalives are on by default and therefore will not show under the interface config. If, however, you elect to change the interval or disable them, it will appear under the interface config.
The command is keepalive
Hope this helps.
04-13-2004 11:56 PM
No one has fiddled with the keepalives.
any more suggestions as to my the issue is happening??
04-14-2004 05:57 AM
helloo sai,
is it link Up or protocol Up (looped).Also tell which LED u r getting on Modem.In the End of show interface serial 0 r u getting DCD UP or not ???
Which modem u r using for that.
regards
SAM
