09-21-2003 03:24 AM - edited 03-02-2019 10:29 AM
I have a remote 2950-24 switch that is working fine, can telnet to it etc. BUT when I try to update the confuguration archive in RME the switch reboots! I have 29 other switches that do not exhibit this when RME updates.
I intend to swap the switch out but has anyone heard of this before? By the way, SNMP access using SolarWinds does not cause a reboot!
Solved! Go to Solution.
09-21-2003 08:01 PM
It's an IOS issue, nothing to do with RME. See: CSCdv35805 via CCO Bug Toolkit. Upgrade the code accordingly.
09-21-2003 08:01 PM
09-22-2003 12:01 AM
I am on 12.0(5.3)WC1 so the bug applies. I will upgrade to 121-6.EA2.
Strange that there are 13 other 2950's on 12.0(5.3)WC1 that work OK. Hence bug I suppose.
Many thanks for that, a day of upgrading looms!
