Community Member
subnets please help
Hi all, can anyone tell me, if I split a class c network in 4 on a 192 mask, the subnet starting 192.168.11.0/192 etc.
how would i reach all 4 subnets via static route, could I just use 192.168.11.0 , would this reach all 4 subnets, or would I have to point each one ? also if I used eigrp would i advertise all 4 seperately ?
cheers
Carl
Silver
Re: subnets please help
your 4 nets are:
192.168.11. 00 | 000000
192.168.11. 01 | 000000
192.168.11. 10 | 000000
192.168.11. 11 | 000000
that is:
192.168.11.0/26
192.168.11.64/26
192.168.11.128/26
192.168.11.192/26
Please remember that the correct bit notation is /26 (24 C class + 2 subnetting) and not /192
for the static route, you have to use a single route that "summarize" all 4 routes: 192.168.11.0/24
for eigrp, something like
router eigrp 100
no auto-summary
network 192.168.11.0 0.0.0.255
would be ok.
If you need to work with eigrp routes, remember that by default, EIGRP summarizes subnet routes to the network level. The no auto-summary command can be entered to configure subnet level summarization, then use 'ip summary-address eigrp' on a specific interface. More infos:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_eih.htm#wp1097180
Andrea
Community Member
Hi Andrea, thanks for your help, do I need to use the eigrp-summary address on my interface,or will it work fine without ? I guess this just stops all 3 networks being advertised out the interface right ?
Also is it possible for me to split the network
into a 128 subnet and 2 64's, how would I do this ?
Community Member
Hi carl,
It will work fine. As you mentioned, it makes advertisements smaller. In this case, it will advertise on network instead of 3 if you configure eigrp...
As i understand u wanna create a subnet which include 128 IP addresses, and two more subnet which includes 64 IP Addresses. Yes it is possible with a enough block of IPs.
Here is a simple calculation for 192.168.11.0/24
Subnet 1
Network Address: 192.168.11.0
Subnet Mask : 255.255.255.128
Subnet 2
Network Address: 192.168.11.128
Both subnet has 128 IP address. Both u can use only 126 of them because the first one is network and the last one is for broadcast.
So lets have 64-IP Subnet
We will use the first one for 128-IP
So we have to subnet the second one to use as 64-IP
Subnet 2.1
Network Address:192.168.11.128
Subnet MAsk : 255.255.255.192
Subnet 2.2
Network Address: 192.168.11.192
After these calculations you have 3 subnets. The first one includes 128 IPs, and the others (Subnet 2.1 and 2.2) include 64 IPs
Regards.
Ahmet
Please Rate helpful posts.
Community Member
is it possible we can have the first 2 64 subnets first and the 128 subnet last (higher in the range) ?
Community Member
Exactly you can...
VLANs are like legos, you can build whatever u want...
But there is one important thing you have to consider is that:
If you wanna use first subnet (subnet zero), you have to configure your switches.
Here is the command:
router(config)# ip subnet-zero
Without enabling this, you cant use first subnet...
Regards...
Pls rate helpful posts...
Community Member
so can i have my first 2 64 ip addresses in the lower range ie 0-64-128 and 128-256, or do u have to use the bigger one first in the lower range ?
502
