10-06-2003 09:17 AM - edited 03-02-2019 10:48 AM
The marketing blurb for this module states it has an oversubscription ratio of 8:1. Can anyone explain this as a 8Gbps connection to the fabric channel shared between 48-ports running at 1Gbps doesn't quite add up............
Andy
10-07-2003 06:31 AM
The card is designed for the wire-closet. As such, the 8:1 oversubscription is a result of the line card architecture. Even though there is a 8G switch fabric connection there is a 6G connection to the front panel, ie 48ports/6Gbps >> 8ports to 1G.
10-07-2003 07:06 AM
So you are saying for each group of 8-ports (6 groups) they have to contend for a single 1Gbps connection??
Andy
10-07-2003 08:08 AM
Yes, that is the oversubscription. 8 ports share 1 gig. At the access layer, end users, traffic patterns are typically such that this isn't an issue. Remember the intent for this blade is the closet, not the data center.
10-07-2003 05:10 PM
Shame then that the data center blade is Sup 720 only.
Unless your servers are very powerful these are fine - most of our dual CPU servers peak at 140 meg. OK for this level of oversupscription.
Our bigger servers are connected to 6516's.
