Webcast-Catalyst9k
sup-bootflash problem
A Catalyst 6513 with supervisiorEngine II has a sup-boot flash, How can I let the ROM know the correct bootup image file is located in the superbootflash?
1 REPLY
Re: sup-bootflash problem
you need to use the following configuration command
boot system flash sup-bootflash:xxxxxx
where xxxx is the filename you are trying to load.
Make sure you remove the previous boot system commands so that your intended file is the first file to load.
use the show boot to verify.
144
