SUP2/MSFC2 Unable to read flash card
Tring to start the procedure to upgrade from hybrid to native mode.
Running hybrid catos/ios on sup2/msfc2...
In catos unable to see card from
dir slot0:
Unable to open slot etc....
Firmware of sup card is 7.1 and size of flash card is 64MB..
Any ideas
Re: SUP2/MSFC2 Unable to read flash card
Do you have any files currently stored in the flash card ?
You may also try on an alternate slot to see if the problem gets fixed
Its possible that the file system in the card is not compatible with CATOS FS. You may have to format the card in the switch.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a00802dcd5c.html#wp1025012
Prasanth is right. For non ata cards its slot 0 and for ATA cards its disk0
152
