Webcast-Catalyst9k
Sup720 for Catalyst 6506
I have an existing Catalyst6506 with MSFC2 Sups. I want to upgrade to SUP720 but the datasheet tells me that I should upgrade to a high speed fan. I have a 3000W power supply.
Does anyone know if it will work with the original FAN?
Thanks!
1 ACCEPTED SOLUTION
Re: Sup720 for Catalyst 6506
Sup720 will not boot, actually, it will boot for about 5 mins and then keeps re-booting. In other words, it will not work.
Please rate this post if it helps.
Yes, you will need WS-C6K-6SLOT-FAN2, I assume that the chassis is non-E chassis (not a 6506-E). The WS-CAC-3000W will be able to support the WS-C6K-6SLOT-FAN2.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm#wp2566779
Please rate helpful posts.
Yes, the chassis is the non-E type. What will happen if i don't install the high speed fan? will it still boot? work?
Thanks!
116
