supernetting with static routes and ospf summary commands
Does the OSPF "summary-address" command for external networks support supernetting. For example "sumamry-address 192.100.0.0 255.255.0.0".
Also, can you configure a static route as a supernet? For example "ip route 192.100.0.0 255.255.0.0 10.1.1.1".
In all the Cisco docs, I have only seen BGP associated with supernetting capability.
1 REPLY
Re: supernetting with static routes and ospf summary commands
You can indeed configure the summary-address range as a supernet.
You can also configure a supernet as a static route such as the example you provided.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
565
