Supervisor Engine 3
1.Is all the default Cat 4006 come with supE3 module??
2. From the attachment, i notice there are ws-x4014, ws-x4306-GB, ws-x4148-RJ module attached at cat. Is that supE3??
Is this cat equipted with routing function??
1 REPLY
Re: Supervisor Engine 3
1. Cat4006 doesnot come default with SupE3 module. The chassis is just blank and you have to chosse the modules that you want to run.AFA Sup 3 goes it is supported on on Cat4006-S3 chassis. If you have any chassis other than the above mentioned, it will not work.Cat4006 chassis also support Sup1 and Sup2.
2 WS-X4014 is the Sup3 with built in routing card/feature on that.WS-X4306and WS-X4148-RJ are the line cards for the chasis.
Please see the link for more info:http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_18a/ol_2170.htm#xtocid4
regards,
-amit singh
80
