Webcast-Catalyst9k
Supervisor Engine Fails on 4506, HELP, tech-support below
Power-On-Self-Test Results for ACTIVE Supervisor
Power-on-self-test for Module 1: WS-X4515
Port/Test Status: (. = Pass, F = Fail)
Port Traffic: L2 Serdes Loopback ...
Port Traffic: L2 Asic Loopback ...
Port Traffic: L3 Asic Loopback ...
0: F 1: F 2: F 3: F 4: F 5: F 6: F 7: F 8: F 9: F 10: F 11: F
12: F 13: F 14: F 15: F 16: F 17: F 18: F 19: F 20: F 21: F 22: F 23: F
24: F 25: F 26: F 27: F 28: F 29: F 30: F 31: F audit: F
Switch Subsystem Memory ...
1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: . 12: .
13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: . 24: .
25: . 26: . 27: . 28: . 29: . 30: . 31: . 32: . 33: . 34: . 35: . 36: .
37: . 38: . 39: . 40: . 41: . 42: . 43: . 44: . 45: . 46: . 47: . 48: .
49: . 50: . 51: . 52: . 53: . 54: . 55: .
Module 1 Failed
Re: Supervisor Engine Fails on 4506, HELP, tech-support below
Can you power cycle the switch once? Turn off all the power supplies and turn them back on. Also make sure it is seated fully and screws tightened. You can reseat it firmly to make sure
I had contact with a Cisco Engineer, the Supervisor Engine had a hardware failure.
134
