Community Member
Supervisor V WS-X4516 Color Status Led (is Orange)
i've a problem whit a new Supervisor
"Supervisor V 1000BaseX (GBIC)" WS-X4516
The Status LED is Orange,
(the power is OK)
Power Fan
Supply Model No Type Status Sensor
PS1 WS-X4008 AC 400W good good
PS2 WS-X4008 AC 400W good good
PS3 WS-X4008 AC 400W good good
I don't know if it is OK or NOT.
i THINK that the good color is green,
Do you help me?
FCostalunga
1 ACCEPTED SOLUTION
Re: Supervisor V WS-X4516 Color Status Led (is Orange)
Here is a link with picture that shows where the PEM is inserted in the chassis:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/cn11189.htm#wp34266
No need to power off any of the power supplies.
The purpose of removing it is just for confirmation, it is not a solution. The solution would be after removing it and if the sup's status LED turns "green". Is to replace the PEM because that will confirm that it's "BAD" as the environment indicated.
Please rate helpful posts.
HI
U r right it shoud be green.i think the sup is not properly initiaized.try reseating it.
Mahmood
Community Member
I reset this, I power off the switch and then power on but the LED is always Orange.
...from ..... # show environment
Power supplies needed by system : 2
Power supplies currently available : 3
Chassis Type : WS-C4006
Power consumed by backplane : 0 Watts
Supervisor Led Color : Orange
Module 1 Status Led Color : Orange
Module 2 Status Led Color : Green
Module 3 Status Led Color : Green PoE Led Color : Off
Fantray : Good
Power consumed by Fantray : 25 Watts
Do you have access to the sup through console? What mode is it in? rommon, no prompt? If you are in rommon, you can try the following:
dir bootflash:
and try to "boot bootflash:" from rommon of whatever IOS you see in the bootflash:. Most likely it's in rommon.
Community Member
The prompt is OK.
Ii sn't in Rommon.
The Supervisor works properly and the switch perform and works at the layer 2 and layer 3 correctly.
It is in HSRP with another Layer 3 switch, but the Led on the Supervisor is Orange.
Then there is nothing wrong with the sup, you might not be looking at status LED which is at the left of the 2 GBIC ports if its a WS-X4516. The ethernet mgmt port also have a link LED and will always be orange as it is not enabled, it is only used for disaster recovery.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/mod_inst/01overvw.htm#wp1070943
The orange light is on the sup on the leaft hand side corener or in the middle under the 10/100 managemant port. If its under that, that means that port is in disabled state.
You should get a green light on this. If its the other case, you take down a picture of this paste here, we would like to check it,
HTH, please rate if it does.
-amit singh
Community Member
i attach the "show environmet" :
Switch#show environment
no alarm
Chassis Temperature = 47 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 WS-X4008 AC 400W good good n.a.
PS2 WS-X4008 AC 400W good good n.a.
PS3 WS-X4008 AC 400W good good n.a.
PEM WS-X4095-PEM -- bad/off none none
Fantray : Good
It was working..............
What do you think about it ?
FCostalunga
The Sup is showing orange LED due to this possible reason:
1. The PEM is actually bad and needs to be replaced - the sup will always show orange as long as the BAD PEM or any BAD power supply is in the chassis.
Try to remove the PEM from the chassis for now and see if the "Supervisor Led Color:" turns to "green".
It is most likely a bad PEM that needs to be replaced.
Community Member
show environmet tell me that the PEM is all OK.
In the previous answer i past the output of show environmet.
What do you think?
Thanks for your help
FC
no alarm
Power Fan Inline
PEM WS-X4095-PEM -- bad/off none none >>>> does not look "ok" to me.
why do you think, it's ok?
Community Member
Thank you.
i don't know what is the PEM.
In my switch i've 3 power.
Can i power off one of this ?
how can i remove the PEM?
EXCUSE ME but for me is the first time that find this word!!!
Can you explain me , what can i do?
thanks
FC
Hi FC,
PEM is your power entry module on 4006 for providing inline power to ip hone. Its an external power shelf used in the chassis.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a00800924d0.html
Please find the link below for PEM module installation:
HTH, Please rate if it does.
-amit singh
Community Member
i remove the PEM.
Now the LED of Supervisor is GREEN.
Thank you for your help.
FC
PEM needs to be replaced.
3201
