SW C2924M-XL post
lebaphuong
I have problem with my switch C2924M-XL. When I turn on the switch, the POST stops when LED 1x turns off (all other LEDs 2x-24x are green). Nothing appears on console. When I press Mode button and turns on switch, the POST stops the same as before and on console appears:
C2900XL Boot Loader (C2900-HBOOT-M) Version 12.0(5.3)WC(1), MAINTENANCE INTERIM
SOFTWARE
Compiled Mon 30-Apr-01 07:34 by devgoyal
starting...
Base ethernet MAC Address: 00:0c:30:0e:bf:00
Xmodem file system is available.
The system has been interrupted prior to initializing the
flash filesystem. The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
flash_init
load_helper
boot
switch:
But I can not write anything on the console
What happen with my switch?
Best Regards
Phuong
Roberto Salazar
Level 8
Level 8
switch: is equivalent to rommon, you should be able to do software recovery through xmodem at this prompt, however, if the switch is not let letting you enter anything at this stage, there is nothing you can do but to replace the switch.
