SWIM and problems uploading code
Can someone confirm that if a device does not support the flash_mib then an attempted SWIM upgrade would fail as per the following error message:
SNMPsvc.pm 236 {4/9/2003 17:14:24}: SNMPsvc (set_resolution) ::Printing to wh103012 =resolve 1
SNMPsvc.pm 241 {4/9/2003 17:14:24}: SNMPsvc (set_resolution) ::Reading from rh203012 '=+ resolve = 1 '
SNMPsvc.pm 472 {4/9/2003 17:14:24}: SNMPsvc (connect) ::Printing to wh103012: [
SNMPsvc.pm 476 {4/9/2003 17:14:28}: SNMPsvc (connect) ::Reading from rh203012: [+
DeviceIOS.pm 140 {4/9/2003 17:14:28}: Device 152.71.1.10 has been connected with Time Out: 10 value and Retries: 2
AccessInfo.pm 35 {4/9/2003 17:14:28}: AccessInfo::fill_in_telnet_access_info
AccessInfo.pm 42 {4/9/2003 17:14:28}: Local User-Password: *
AccessInfo.pm 51 {4/9/2003 17:14:28}: TACACS User-Password: *
AccessInfo.pm 60 {4/9/2003 17:14:28}: ETACACS User-Password: *
AccessInfo.pm 69 {4/9/2003 17:14:28}: Telnet Password-Enable Password: ************
AccessInfo.pm 76 {4/9/2003 17:14:28}: Enable Secret: *****
TftpSvc.pm 135 {4/9/2003 17:14:28}: TftpSvc::get_tftp_server_ip_address for 152.71.1.10
TftpSvc.pm 110 {4/9/2003 17:14:28}: NATed IP properties reading
TftpSvc.pm 144 {4/9/2003 17:14:28}: No NAT Entry Found,So skippingTftpSvc.pm 233 {4/9/2003 17:14:28}: Outgoing Interface detected as 152.71.0.230
DeviceIOS.pm 700 {4/9/2003 17:14:28}: DeviceIOS::_check_flash_mib_support
DeviceIOS.pm 873 {4/9/2003 17:14:28}: DeviceIOS::_is_mib_var_available //mib_var_name = 'netConfigName'//
SNMPsvc.pm 882 {4/9/2003 17:14:28}: SNMPsvc (_raw_get) ::Printing to wh103012: <netConfigName
SNMPsvc.pm 887 {4/9/2003 17:14:28}: SNMPsvc (_raw_get) ::Reading from rh203012: <+
SNMPsvc.pm 897 {4/9/2003 17:14:28}: SNMPsvc (_raw_get) ::Printing to wh103012: ?
SNMPsvc.pm 901 {4/9/2003 17:14:28}: SNMPsvc (_raw_get) ::Reading from rh203012: ?+ netConfigName[0]="";
DeviceIOS.pm 891 {4/9/2003 17:14:28}: //inside is_mib_var_available mib_var_name = 'netConfigName' result: 1//
DeviceIOS.pm 873 {4/9/2003 17:14:28}: DeviceIOS::_is_mib_var_available //mib_var_name = 'chassisSysType'//
SNMPsvc.pm 882 {4/9/2003 17:14:28}: SNMPsvc (_raw_get) ::Printing to wh103012: <chassisSysType
SNMPsvc.pm 901 {4/9/2003 17:14:28}: SNMPsvc (_raw_get) ::Reading from rh203012: ?- <100251,2239,1> SNMP Get failed for device 152.71.1.10
SWDErrCode.pm 470 {4/9/2003 17:14:28}: Error returned in 'd:/PROGRA~1/cscopx/cgi-bin/swim/swd/SNMPErrCode.pm:121'
SWDErrCode.pm 471 {4/9/2003 17:14:28}: Error Code: '4031'
SWDErrCode.pm 472 {4/9/2003 17:14:28}: Error Message: 'Device Error: No such instance of MIB in the device.'
SWDErrCode.pm 473 {4/9/2003 17:14:28}: Error Action/Reason: 'Probable Cause: Invalid table index or MIB not supported on device. Recommended Action: Restart Resource Manager Essentials and retry the operation. If the problem persists, contact your technical support representative for assistance.'
{4/9/2003 17:14:28}: SNMP error message: Device Error: No such instance of MIB in the device.
< Low Level SNMP Code: Perl Error: -1 SNMP Error: '100251' SNMP Error2 : '2239' Var Bind: '1' SNMP Error String: 'SNMPsvc:get failed
SNMPsvc: ?- <100251,2239,1> SNMP Get failed for device 152.71.1.10
Documentation implies that the 2950s are supported but this customer is experiencing problems with his SWIM upgrades. Any suggestions would be welcome.
Nick :)
  • Other Network Infrastructure Subjects
Blue
Re: SWIM and problems uploading code
RME 3.4 with IDU 3.0 installed?
Yes, IDU 3.0 is installed. Any other suggestions?
The flash MIB is only needed when you want to import the image to the library. For distribution it's not needed, so that's not the reason for this failure. What type of image are you distributing? tar or bin file?
Make sure the solftware version of the 2950 is at or above the version listed in
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_device_support_table09186a00800e7ae3.html
The answer is the mib isn't supported in the device. If you walk the mib in the device you'll be able to confirm this. There were several challenges with the 2950s so make sure the code is up the specs at a minimum.
The current image is 12.1.9EA2C and trying to upgrade to 12.1.9EA1D, both images are bin images.
87
