Switch 1924 Does not go to POST
Does anybody know how to fix this, i get 1-3-6 ports on my switch AMBER, cisco(Trblsht) says replace firmware did this already... i am starting to think it might be my Mem anybody ever run into this problem??
1xNonfatal---Port loopback test.
3x Fatal---Content addressable memory test. Switch is not operational. Contact Cisco Systems.
6x Fatal---CAM SRAM test. Switch is not operational. Contact Cisco Systems.
1 ACCEPTED SOLUTION
Re: Switch 1924 Does not go to POST
Hi Friend,
I believe this is a hardware failure and you may need to contact Cisco TAC to get it replaced.
Have a look at different POST results
http://www.cisco.com/univercd/cc/td/doc/product/lan/28201900/1928v67x/19icg67x/19ictrbl.htm#xtocid209651
Ankur
1 REPLY
Hi Friend,
Ankur
107
