switch 2970 - performance issue
has somebody an idea what can cause the following behaviour in that environment and how to eliminate this
Environment:
Windows 2000/2003 servers, HP teaming, Cisco switch 2970 12.1(19)
Issue:
transfer of 1GB takes X seconds
transfer of 2GB takes 3X second
transfer of 4GB takes 15X seconds
transfer of 8GB takes 40X seconds
Thank you for any advice, comments
Jan
Re: switch 2970 - performance issue
What is the performance if you disabled the teaming?
I tried to disable/disolve the teaming. However it didn't influence the mentioned behaviour.
Jan
I think you need to get a baseline here before you start blaming the switch. I suggest you take a crossover cable and connect your test PC to a server and perform your data transfers. I would do about 10 tests for each size and average the results out. Once you have this baseline for each transfer size you should then re-test via the switch.
You will not see any performance increase using teaming (load balancing) as your connections will only ever use the same path. The load-balancing comes into play when you have multiple clients - the algorithm uses either layer-2 or layer-3 information to decide which physical port in a channel will be used. In a connection between 2 devices this will always be the same physical port/link.
Andy
121
