Switch 4908- Timeout with large packet of 64K
I was making test with PING command, beteween two WAN points, when the ping is made without biggers packets the response is good, when I put 64K the response is timeout.
If I use QoS setting the perfomance will be better?
1 REPLY
Bronze
Re: Switch 4908- Timeout with large packet of 64K
You should check your interface stats to see if you are dropping alot of packets. If the problem is congestion, then some sort of QoS would help, if the problem is with the circuit, you will need to contact your telco for further troubleshooting.
135
