07-24-2003 02:10 AM - edited 03-02-2019 09:05 AM
We have 2 2950 switch, new ones.
I want to add an ip address to those switch but i cant find the command to do it, and every white paper i read about that give the ip address command which gives me an error message when i type it on tge switch...
If u know how ti do that plz, let me a simple walkthrought...
Thx
Solved! Go to Solution.
07-24-2003 02:19 AM
If you work with one Vlan,
enable mode,
conf t
int vlan 1
ip address 192.168.0.1 255.255.255.0 <- ip adress of the switch.
no shutdown
exit
exit
wr.
Else you have got the configure mode :
enable mode
configure and follow the guide lines.
Regards.
07-24-2003 02:19 AM
enable mode,
conf t
int vlan 1
no shutdown
exit
exit
wr.
enable mode
Regards.
07-24-2003 02:41 AM
Perfect...U couldn't be more clear
Many Thx
07-24-2003 02:32 AM
