dwu
Switch between Telcom router and firewall
I would like to set up a switch as outside, it 'sits' between telcom router and out firewall untrust.
router e1 -> cisco switch ->firewall untrust port, firewall trust port->our inside switch.
my question: how can I set up a management ip address for this outside switch to manage it from our inside network.
Thank you in adv.
Re: Switch between Telcom router and firewall
Since you are managing it from inside interface of firewall you should be able to configure the switch (vlan 1 or any management vlan) with a public IP address from the same subnet as the firewall and router.
Preferably use SSH over telnet.
dwu
our router is managed by XO, firewall untrust 71.5.51.130, trust 192.168.11.1.
router - switch - firewall
can I assign 71.5.51.129 for the switch between? just wondering...
108
