switch code upgrade copy and paste
When uprading code using the 3548 switch http interface is there an easier way to input the new image filename than retyping the file name for each switch. Is there a way to cut and paste the file name even tho you are using java. Thanks
1 REPLY
Silver
Re: switch code upgrade copy and paste
I have not used this GUI, but I have seen in some cases the cut & paste may not work with keyboard shortcuts, whereas the right click on mouse might give you the copy and paste options
84
