Webcast-Catalyst9k
Switch code Upgrade
Suppose a location has 500 access level switches say 6509s. And, it is required to upgrade the code on these switches.
What is the best way to do this task? with minimum effort and time.
TIA
Shahbaz
Re: Switch code Upgrade
If you have Cisco Works, use it to push out the new code to the switches. Then use it to change the 'boot system flash bootflash:new CAT code command to show up first in the order.
Once this is completed schedule in CW the switches to be rebooted.
Without CW, it appears to be a manual process.
Hope this helps.
Suppose you can not use Cisco Works then what will you do?
best model for this is just to start doing it manually:
format bootflash:
all sectors will be erased, proceed (y/n) [n]? y
enter volume id(up to 31 characters): enter
copy tftp flash
ip address or name of remote host (enter ip of host holding new code) x.x.x.x
name of file to copy from? /whereever/cisco/cat6000-code.bin
name of file to copy to:cat6000-code.bin
you have so much space on bootflash,proceed(y/n) y
then set boot strings:
clear system boot all
set boot system flash bootflash:cat6000-code.bin
Im just curious as to why you are using 6509's for access layer...
(0_o)
84
