Community Member
Switch connectivity problem
HI All
I have 2 Cisco Switches (5500 & 2900) both are connected thru a cross cable. My Server is at 5500 and some of clients are at 2900 everything works fine but after every 3 to 4 days my client lost connection from the server. If i restart my 2900 SW then problem gets resolve. Can any one highlight the problem?
Silver
Re: Switch connectivity problem
The following troubleshooting document might help.
http://www.cisco.com/warp/public/473/46.html
Community Member
If client/server is on the same vlan, than most likely it is a local port problem on the 2900. When problem occurs, access the 2900 and capture the commands.
- show interface mod/port (check if input counter increment)
- show mac dyn interface mod/port
- show spanning-tree interface mod/port
-Robert
110
