Switch for autoQos
I am planning to create a network for voice and data and I want to enable AutoQoS for the IP telephones.
I am plannin to use the switches
WS-CE500-24TT
Have they the AutoQoS function?
Is a good selection?
  • Other Network Infrastructure Subjects
Re: Switch for autoQos
hi,
http://www.cisco.com/application/pdf/en/us/guest/products/ps708/c1031/cdccont_0900aecd80488013.pdf
this link have all the feature comarision for various switches.
remeber to rate the post if it helps
regards
Devang
Hi there,
You should have no porblems with these switches. They run PoE to power the phoens and you can configure QoS on them using the fancy smartports. Smart ports are very easy to configure, just point and click!
There are lots of other switches that you could use, but if the 500 fits you needs and your budget - then that's the one for you.
FYI:-
http://www.cisco.com/en/US/products/ps6545/products_data_sheet0900aecd80322aeb.html
Best regards,
LH
CCIE#15331
112
