Switch is calling for help
and I don't know what to do for it!
My 2900 Catalyst XL has three VLANS on different subnets. VLAN1 is on my WAN. Port 1 is connected to the WAN port of my firewall, Port 2 is connected to Ether0/0 on the 2611 router. I haven't been able to telnet to the switch and get it to respond so I consoled in and found it constantly complaining with:
4w5d: %LINK-4-ERROR: FastEthernet0/2 is experienc 156169061 packets output,
4034345596 bytes, 0 underruns
A show interface of the two ports provides this information:
FastEthernet0/1 is up, line protocol is up
Hardware is Fast Ethernet, address is 0002.b921.eb41 (bia 0002.b921.eb41)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 296000 bits/sec, 93 packets/sec
5 minute output rate 154000 bits/sec, 88 packets/sec
160873385 packets input, 3764204731 bytes
Received 261694 broadcasts, 0 runts, 0 giants, 0 throttles
3 input errors, 3 CRC, 0 frame, 3 overrun, 31 ignored
0 watchdog, 0 multicast
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
FastEthernet0/2 is up, line protocol is up
Hardware is Fast Ethernet, address is 0002.b921.eb42 (bia 0002.b921.eb42)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 254/255, txload 14/255, rxload 20/255
Keepalive not set
Auto-duplex (Half), Auto Speed (10), 100BaseTX/FX
Last input 00:00:01, output 00:00:01, output hang never
5 minute input rate 820000 bits/sec, 277 packets/sec
5 minute output rate 576000 bits/sec, 266 packets/sec
655397189 packets input, 2921246542 bytes
Received 269594 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 2243 ignored
0 watchdog, 47931 multicast
595696938 packets output, 3180169608 bytes, 0 underruns
8425916 output errors, 19576897 collisions, 1 interface resets
0 babbles, 8425916 late collision, 25530974 deferred
ip nat inside source list 199 interface VLAN1 overload
access-list 199 dynamic Cluster-NAT permit ip any any
snmp-server engineID local 0000000902000002B921EB40
--More--
4w5d: %LINK-4-ERROR: FastEthernet0/2 is experiencsnmp-server community private R
Any ideas what I need to do to alleviate its problem? It appears to be working but is clearly not happy!
Thanks for any input!
Pat
Re: Switch is calling for help
Pat,
I did notice in your output that e0/2 autoset itself for half dulplex. You have a very high number of late collisions. This indicates something full duplex is stepping on the port. You should manually configure your duplex and speed settings and see what happens.
Scott
That fixed it! Many thanks and Merry Christmas!!
Pat
92
