Webcast-Catalyst9k
Switch Problem
I have 2 Switches 2924XL connected with 2 Fiber Link on ports 23 and 24, the port 24 led is Ambar, but I can not find anything wrong, the show command is :
Switch03#sho int fast 0/24
FastEthernet0/24 is up, line protocol is up
Hardware is Fast Ethernet, address is 00d0.06fa.d95a (bia 00d0.06fa.d95a)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, rely 255/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive not set
Full-duplex, 100Mb/s
Last input 00:00:00, output 00:00:18, output hang never
Last clearing of "show interface" counters 05:42:17
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 9000 bits/sec, 7 packets/sec
297162 packets input, 72265070 bytes, 0 no buffer
Received 131109 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 18250 multicast
348665 packets output, 109971976 bytes, 0 underruns
0 lost carrier, 0 no carrier
Anyone can help me ?
Alex
Re: Switch Problem
If you connect 2 switches via 2 connections with the same VLAN configuration, one port will go into the STP blocking state and go appear on the front panel LED. This is correct behavior.
Re: Switch Problem
Thanks for your reply, but what means STP blocking ? The 2 connections is load balanced ? If no, how can I do it ?
Alex
Re: Switch Problem
Do you have Ether Channel configured between switches?
Re: Switch Problem
No, How can I do it ?
Alex
Re: Switch Problem
If you have CatOS (5500, 6500, 2900G switches)
http://www.cisco.com/warp/public/473/68.html
If you have switches with Native IOS2900XL, 3500XL
http://www.cisco.com/warp/customer/473/131.html
If you are trying to configure ether channel between CatOS and 2900XL/3500XL
http://www.cisco.com/warp/customer/473/44.html
If you have any questions e-mail me directly :khramov@nsuok.edu
Re: Switch Problem
Does th light stay amber all the time, or only for a few minutes when the switch first boots up?
Daniel,
Re: Switch Problem
Sorry I forgot to add, if the light stays amber all the time then you have a configuration conflict between the f0/24 interface and the device at the other end of the link. STP only turns the light amber whilst it recomputes the listening and learning states (about 30 secs). Amber means the link has come up but is not functioning
Daniel,
160
