Switch Recommendation
I am looking at replacing our 10 Base T network with a 100MB switch solution.
Can anyone recommend a reliable switch. At the moment I am just looking for a 24 port 10/ 100 MB switch - nothing too fancy
My main concerns would be ease of installation, general maintenance and if possible network utilization.
Thanks in advance for your help
Re: Switch Recommendation
You should consider buying C2950 if you only need Layer2 functionality. If you think you will need routing functionality then perhaps C3550 is a resonable choice.
Silver
Thanks for the quick replies and links
There are a few models in the 2950 series which I have narrowed down to :-
CISNA024TN (WS-C2950T-24)
CISNA024TM (WS-C2950-24 )
Or Should I be looking at the 2950G range?
Silver
Well, according to your first post, I'll choose WS-C2950-24. Switches 2950-T and 2950G have Gigabit uplink ports and Enhanced Image software. So, unless you are planning to place a Gigabit Eth backbone in the future or require special features such advanced QoS, high avalaibility, etc. you shouldn't choose others.
I think you also should ask for prices.
Bit of a jump in price on the 2950G range!!
Would the extra features of the 2950-T give us a little more "future proofing" or will it only cause more problems on setup?
96
