switch-switch giga uplink failed
two WS-C2950T-24 switches connected thru their g0/2 ports , the link is inactive; changing any one side to fast eth restores the connectivity and both g0/2 are functional in at 100mbps. POST detects all h/w as OK. The g0/1 of the switch is connected to another identical switch in a similar fashion and is working fine.
IOS ver of both switches are :IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(11)EA1, RELEASE SOFTWARE (fc1). The link was functional earlier. Incident to note was a lightning strike on a nearby building after which the failure was noticed. The switches are powered thru online UPS.
pls let me know how the issue can be resolved.
pls revert at my mail id : kthyagarajan@wipro.co.in
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: switch-switch giga uplink failed
If there is some damaged caused to the hardware due to lightning, I think you diagnose the problem only by doing RMA of the failed unit.
Just to confirm that it is a hardware failure, you may want to swap the devices with the same configs.
78
