06-27-2003 11:54 AM - edited 03-02-2019 08:29 AM
Is connecting a Fast Ethernet hub to a Catalyst 5500 a bad thing? If not, what is the proper way to connect them.
06-27-2003 12:02 PM
Its a reversion to old technology. The Cat port can only run half duplex. The users on the hub will share a collision domain. It will work, its not too bad for slow low use devices. It takes a cross over cable or the hub might have an uplink port that will do the cross over. It might have a button that controls if the port is crossed over or not.
06-29-2003 01:41 PM
And you shouldn't run Spanning Tree PortFast on the port connected to the hub in case someone loops two ports on the hub.
07-02-2003 05:39 AM
spanning-tree portfast bpduguard
is necessary to prevent a loop problem in the case someone loops two ports on the hub.
Disabling Spanning Tree PortFast is not enough.
Milan
