Webcast-Catalyst9k
Switches with CAR feature.
I'm looking for a small/medium catalyst with CAR(Commited Access Rate) feature for customers' access control purposes.
Could you suggest me one?
I read about 2600 router with NM-ESW-161 that could solve my problem. But, I have no information about the provisioning way to enable VLAN, 802.1Q trunk and CAR features on ports.
Can this router with this module perform theses features ?
Thanks in advance.
Re: Switches with CAR feature.
NM-ESW16 does not support CAR on each port . It might support VLAN based rate-limiting(I have not tested it). The following document should help you with other configuration(vlan/trunk)
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xt/122xt_2/ft1636nm.htm
You might want to consider the CAT3550 switches
http://www.cisco.com/warp/public/cc/pd/si/casi/ca3550/index.shtml
http://www.cisco.com/warp/public/473/153.html
Thank you very much !!
I will perform some configurations in CAT3550 to test the traffic pollicing.
Do you have some examples of VLAN based rate-limiting ???
3550 does not do vlan based policing currently. It is planned for a future release. currently per-port policing (ingress/egress) is only supported.
123
