Community Member
Switches with multiple Class C's??
Is there a switch that can be configured so one group of ports is assigned to one Class C (WAN) and a second group of ports is assigned to a different one (LAN)?
Community Member
Re: Switches with multiple Class C's??
You can configure switches with Virtual LANs (VLANs). A VLAN is a broadcast domain. If you configure one group of ports on VLAN 1 and another on VLAN 2, you can assign IP addresses like:
192.168.1.0/24 to VLAN 1 and 192.168.2.0/24 to VLAN 2.
You will need a router to route between the two VLANs. A layer 3 switch will provide the router services as well.
Mick.
Community Member
Thank you, Mick! Can you give me the model number of an example of a Layer 3 switch? I presently have a 2900XL.
Pat
Community Member
Hi Pat,
I know that cisco 2621 can do the trick, but it has limited number of ports. You might need to use a switch/hub if you need more ports. Cisco 6509 is faster and provides up to 288 fast-ethernet ports, but it costs much more than cisco 2621 and a switch.
Hope my info help.
Good luck.
Community Member
Hey Pat,
The Cisco 2621 is a dual fast-ethernet port router not a switch , but you can use it to connect to your 2900 and route between VLANs. If you want to move up to a chassi based L2/L3 switch, the 6500 is obviously great but expensive, or you can go with a 4000 series or even an older 5500 with RSM module will work fine.
Good luck.
Community Member
Thanks all! I have to go play with my switch now! My boss is about to buy me a new router so I better get the switch configured and online before the new toy gets here!
157
