Webcast-Catalyst9k
switching module sessions?
I know that when in CatOS switching side, you can connect to your MSFC card by issueing the 'session <mod>' command. But is there something similar to get from the MSFC IOS prompt into the CatOS prompt on the switch side?
Greg
Bronze
Re: switching module sessions?
If you've accessed the MSFC using the session command, issue the exit command or the logout command to switch back.
If you've accessed the MSFC using the switch console command,hit Ctrl-c three times to switch back.
That's good to know, but not quite what I meant.
If I telnet from my PC to the SUP card, I can switch to the MSFC using the session command.
If I telnet from my PC to the MSFC card, I can switch to the SUP using the ????? command.
Please fill in the blank.
There is no special command to switch from the MSFC to the SUP such as the one available from the SUP to the MSFC. You can always use regular telnet to do so though.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
262
