Switchport mode trunk question
cindylee27
Hi Experts,
I have 2 switches. One is switch 3020 and the other one is switch 3750. The port 17 of switch 3750 is configured as trunking port, as below :
switchport mode trunk
speed 1000
duplex full
The other port 17 at Switch 3020, is configured as below:
interface fastethernet0/17
switchport access vlan 33
I have a server connected to port 15, vlan 31.
There is also virtual interface of vlan 31 at 3750 with hsrp standby ip.
The question is.. why I am still able to ping to the server from a user that connected to 3750 since the vlan at the trunking is only 33?
Thanks in advanced.
The setting "switchport access vlan xxx" determines the vlan ID for the port WHEN it is in access mode. To hard-code it in acces mode you need to enter the command "switchport mode access" as well.
This setting widely recommended as a security measure for ports that you do not want to use as trunks. In this way you can prevent that the attachment of a switch allows access to any vlan in the network.
Leo
5 Replies 5
lgijssel
Level 9
Level 9
As you have not specified the port at the 3020 to be in access mode (switchport mode access) the default is in operation.
The default is auto-trunking; when a trunk is discovered on a port, a trunk is established.
You can verify this by checking: sh int ../17 switchport.
This will give you the operational trunking mode.
regards,
Leo
Thanks Leo..so this trunking will also applied even when the switchport access vlan xxx is configured at the switchport ??
meaning it can take all the vlans numbering across right? ;)
Thanks again..
Leo
Thanks Leo..
Helpful reply.. :)
Have rated your post..
Rating posts is always good.
Thanks a lot!!
