?switchport protected between switches
I have several 2950's and 3550's hung on trunks off a common 3550 EMI.
Configuring switchport protected on interfaces disables L2 communications between these interfaces on the same switch.
Can anyone tell me a sane/simple way to disable L2 between interfaces on the same VLAN on different switches?
Thanks.
Hall of Fame Super Bronze
Re: ?switchport protected between switches
What exactly are you trying to achieve ?
Are you trying to block a port between switches ?
Switchports default to L2 and can only be changed to L3 if running a 3550 or later, with the no switchport command.
Ref attached jpg
I hope to find a way that restricts workstations (designated A-E on jpg) configured on the same vlan to communicate only to designated servers and the default gateway.
These workstations should get no reply when arping to any other on net address.
I understand that switchport protected does this when configured for workstations residing on the same switch as the server and gateway. (ie. the rightmost 2950)
I believe I understand now.
switchport protected works on the same switch while you want to expand this concept over multiple switches,
am I right ?
Well, there is an option, it's called Private Vlans but it's supported on 3560/3750 and other high-end switches.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_35_se/configuration/guide/swpvlan.html
Thanks.
As I understand it then, all hosts connected to associated primary and secondary private vlans occupy the same ip subnet with a gateway configured on the primary vlan's svi.
Short of replacing all switches with 3560/3750's, could I get L2 isolation by
1. replace the 3550 at the root with a 3560 trunked to both 2950's.
2. configure the 3560 with private primary vlan X with associated private isolated vlan Y
3. configure all 2950 ports connected to workstations as switchport access vlan Y and switchport protected.
4. configure the 2950 ports connected to the server as switchport access vlan X and no switchport protected.
It might work but just thinking about it, gave me a headache :)
Best to draw it up and play around with that idea in a Lab.
630
