03-04-2003 05:49 AM - edited 03-02-2019 05:33 AM
I have now been geting this message at 9 pm and 6 am since the module was changed last week. Which means at this times, we loose some network connection.
Please can anyone tell me what is wrong and how I can rectify this. We are running
WS-C6509 Software, Version NmpSW: 6.3(9)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Sep 23 2002, 19:03:06
System Bootstrap Version: 5.3(1)
System Web Interface Version: Engine Version: 5.3
n: 1.6 ADK: 40 and I noticed that the new module has a different Firmware version - Fw : 4.2(0.24)VAI78.
Thanks for your help.
03-04-2003 06:01 AM
SYS-3-MOD_PORTINTFINSYNC: Port Interface in sync for Module [dec]
Explanation This message confirms that the module booting up has synchronized the onboard ASICs that handle the transfer of packets between the backplane and the network ports. [dec] is the module number.
Action This message is provided for information only.
Do a sh log and see if module 7 is being reset. Also do you see any reset messages from output of "sh logging buffer"?
03-04-2003 06:23 AM
Thanks. As it is showing a 3 which means critical. is it really informational? Please note that this has been happenig since at least 2ce a day since the module was changed. Shold it still be trying to synchronise?
No I do not see any reset messages, only the message above.
03-04-2003 06:07 AM
I would not think this message is the cause of your problem. This message just means the card ASICs have synch'd with the SUP. Most of these I see are from cards that are inserted (might be restarting due to some other problem)
or a High Availability setup that could be causing this. You might run a "show test" to see of this module has had any diagnostics problems.
Here is the message meaning:
for Module [dec]
number.
Hope this helps you,
Don
