Community Member
syslog issue
ok syslog in switches, default logg severity is 4, people want to see config changes which is a sys facility with a severity of 6, so if you change logg serve severity to 6, it works and loggs config changes, but also loggs all pagp level 5 events which is ports deinsserting and reinserting, so i figure if i set logg serve severity to 4 and set logg level sys 4 default this should change sys messages to a severity of 4 and thereby the should be logged, this doesnt work, any ideas?
1 REPLY
Re: syslog issue
try
set logging server severity 6
set logging level sys 6 default
set logging level dtp 4 default
or set logging eth 4 default
I'm not sure 100% which logging facility handles PaGP.
Generally
set logging server severity 6 tunes the minimum severity of syslog messages which are sent to syslog server.
But you can additionally tune particular groups of messages (called facilities) by the set logging level ..... x default command.
Use sh logging command to see the list of facilities supported and thier default and current logging level. (The difference between deafult and current: if you omit the "default" option in the set logging level ..... x command, you change only the current value and the logging level will return to the default value after you logout from your session.)
See http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_1/config/logging.htm for details. This article is not user friendly, but I don't know any better.
Milan
221
