03-29-2004 09:09 PM - edited 03-02-2019 02:38 PM
I am using Syslog Analyzer to collect syslog messages form switches and routers. From syslog analyzer, I see:
30 Mar 2004 19:51:49 CST Configured from console by ns010185 on vty 0.
And from show logging, the same message is
Mar 30 11:51:49 gmt: %SYS-5-CONFIG_I: Configured from console by ns010185 on vty 0 (10.100.254.166).
The time now is 11:51:49. Why it is 8 hours earlier than it really is ?
03-29-2004 09:59 PM
There are only certain timezone acronyms and zones supported by CiscoWorrks.. Have a look at this link..
http://cisco.com/en/US/products/sw/cscowork/ps3996/prod_release_note09186a008017adfc.html#1039999
You will find the same for your version/platform on the Cisco site.
Hope it helps..
03-30-2004 12:08 AM
it seems like your switch is using GMT in syslog while CiscoWorks are using CST.
Have you configured
service timestamps log datetime msec localtime
in the switch config?
Then it will use local time in syslog timestamps.
You can configure the local time offset from GMT using
clock timezone CET 1 (e.g.)
command.
Milan
03-30-2004 06:58 PM
I had already configured 'service timestamps log datetime msec localtime show-timezone'.
Switch#sh clock
10:51:53.552 GMT Wed Mar 31 2004
It is learned from NTP server.
From CiscoWorks>RME>Administration>Syslog Analysis>Syslog Collector Status, the syslog analyzer is using the right time. But the log messages from reports is wrong.
03-31-2004 03:44 AM
search the online help of Cisco Works for the following:
country code
search all words
in Syslog Analysis
the first you get is Overview: Syslog Analysis
there you get info how Syslog Analysis handles time and timestamps.
03-31-2004 05:14 AM
If you change the solaris to use DST/GMT time and use the same on cisco device even that the cisco devices can use summertime with specific area definitions and the solaris can't it works fine for me.
I have TZ=DST-2 on the solaris(Because of the summertime is running right now)
and have
clock timezone DNT 1
clock summer-time DST recurring last Sun Mar 2:00 last Sun Oct 3:00
clock calendar-valid
on the IOS box
04-15-2004 11:01 PM
I met the same problem.
I find the following in help of the Syslog Analysis Overview:
Managed devices send syslog messages that contain a time stamp reflecting the device's local time zone. Because the device time zone might differ from the server, the Syslog Analyzer converts time stamps in all Syslog messages to GMT format for all supported time zones. If a device time zone is not supported, the server time zone is used. If a managed device is not configured to send time zone information with its messages, Syslog assumes the device resides in the server time zone and uses that time zone in the message time stamp. For example, if a managed device in India is set to the local time zone, sends a syslog message to an Essentials server in California, and the message is then viewed on a client browser in New York, the message will reflect California time.
It is recommended that you set the country code variable with the appropriate country code in the Sa.properties file located in the directory NMSROOT/lib/classpath/com/cisco/nm/sysloga/sa, to make sure that the Syslog timestamp conversion works correctly. For example, if you are in Singapore, you must set the country code variable as COUNTRY=SGP.
For a list of country codes, see the file, CountryCode.txt, located in the directory, NMSROOT\lib\classpath\com\cisco\nm\sysloga\CountryCode.txt. The country code is the 3-letter abbreviation specified in the CountryCode.txt (in column A 3).
Syslog reports are always displayed by converting stored GMT time to server time.
Hope these can help you.
05-11-2004 06:56 PM
I have modified the Sa.properties ,set the country code as COUNTRY=CHN and restart the server. It still doesn't work.
05-12-2004 12:29 PM
One of the previous answers stressed the importance of configuring service timestamps logging which includes the parameter "localtime". You responded that you had indeed configured this.
The aspect that has not yet been pointed out is what does the switch think localtime is. There is a clue in the log message:Mar 30 11:51:49 gmt: %SYS-5-CONFIG_...
and it is even more clear when you did
Switch#sh clock
The switch is using GMT (Greenwich Mean Time) which it is learning from the NTP server.
What you need to do is to configure the local timezone (set timezone CST -6 0). You may also want to configure daylight savings (set summertime enable CDT)
