System Crash
Dear all
The router, 1710, is reboot in this morning. I do the 'sh ver', which getting the error.
System Return to ROM by error a SegV exception PC, 0x80af5798. Do you know what is it? Is it critical? Please advice. Thanks
Godwin
1 ACCEPTED SOLUTION
Re: System Crash
Godwin,
THe show version has a statement saying...
System returned to ROM by error - a SegV exception, PC 0x80AF5798
More on SegV exceptions can be read here...
http://www.cisco.com/warp/customer/122/crashes_segv.html
This exception is due to a software error, can be caused due to a bug in IOS. Upgrading to a latest version of IOS should help in resolving the issue.
The sh stacks file was indeed very big. Decode of the stack output also indicates that the error was due to a software defect.
I would recommend you to upgrade to latest code, after checking whether you have enough amount of ram/flash.
Re: System Crash
Godwin,
SegV exception usually occur, when a software routine tries to access some areas of memory, outside the allocated memory space. Can you paste a show stacks and show version output for further troubleshooting?
Or you can use these outputs at the Output interpreter tool and see if there are any related bugs in the software.
Re: System Crash
Thank you for your response. However I am no right to access the output interpreter tools.
Godwin
Re: System Crash
Ok, if you can paste the outputs of show stacks, sh version, we can decode that for u to see if there are any potential bugs.
Re: System Crash
Thanks for your help. I have sent the e-mail with attachment to you. Please help to decode the crash dump. Thanks
Godwin
Re: System Crash
Godwin,
Re: System Crash
Thank you for your help. Where can I get the latest IOS? Please advice. Thanks
Godwin
346
