System information in Catalyst 4006 with sup engine III with IOS 12.1(EW)
I was wondering whether we can see system information like chassis properties like environment, modules present and configured interfaces in one command.
Would there be a event logging mechanism for later viewing like access to the system via telnet with timestamps or any error conditions for example.
I appreciate the thoughts.
Re: System information in Catalyst 4006 with sup engine III with
Will a "sh tech" help?
Yes.
show env
show mod
show run or show interface status
you can enable event logging via the usual IOS sysloging configuration.
Thanks for the help. I think "sh tech" is not a valid command in IOS and also sh run and this may work probably in catos. But we are migrating from Nortel to Cisco at the core and have bought these new line of switches with native IOS and never worked with cisco before. sh env and sh mod works fine. I need to readup the documentation has how to setup syslog to setup event logging. Thanks for all the help. Actually sh tech and sh config works in Nortel Passport series switches which brings up everything from module to configurations like sysup time, what revision of code the module is and is a good diagnostic tool. I appreciate the quick response. Thanks.
sh tech is a valid command in IOS. You need to be in enable mode
Switch#show tech-support
I strongly suggest that you read the documentation and use the command reference below
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_11/index.htm
I am thankful for enlightening me about these commands. I am sorry that I didn't specify in which mode I was when the command didn't work. Good learning experience. Thanks.
158
