System Ok light keeps blinking!???
I have a 1605-R, that when powered on the System OK light on the front panel keeps blinking, normally indicating the boot process. I let it go for 15 minutes just to be sure it dosen't eventually end up booting properly.
I can't get access to the console port either, perhaps related to the same issue?
Any ideas?
Thanks.
Charles
1 REPLY
Re: System Ok light keeps blinking!???
As you mentioned, system LED blinking is normal during bootup
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1600/1600icg/trbsht.htm#32958
Regarding you not able to console in, are you able to console into any other cisco device with the same cable/pc? I want to make sure the cable/console settings are good. If so, and you see nothing on the 1605 console, try sending a break after you reboot the router. If you are able to break into rommon, try a manual boot
758
