bockri
One of our 7206 have problems with self-boot. Some says that the message system returned to ROM by power-on means that someone have physically booted the router or the we've had loss of power. Is this true or can there be other explanations for the outline in sh version? The sh log shows this msg: No More free buffer in vnm_dsprm_free_msg_Q
00:00:20: vnm_dsprm_line_status_from_port: failed on 5 card
j-lau
If you have the message "returned to ROM by power-on" means physical AC power was interrupted by whatever means. If someone boots the router (software reset i.e. CLI), the message will be ".... system restarted by reload."
System returned to ROM by power-on indicates power loss to device.
GF-CP-SW01#sh version
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE3,        RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:57 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTW        ARE (fc1)
GF-CP-SW01 uptime is 13 hours, 51 minutes
Sent: Tuesday, January 19, 2016 6:26 PM
Subject: RESET: Node GF-CP-SW01 is Up.
 Node was down for 144 minutes.
Yes, after checking and investigation we found that AC power was interrupted.
