Community Member
T1 Hub?
I have a 1720 router with 1 ethernet port a S0 and a S1. The S0 and S1 have a T1 line running into it. I need to add a third T1 but the router has no more module slots available. Is it posible and is there such a thing as a T1 hub so that I can run 2 T1 lines into the S1 port? Please send any replies to
dalebosley@msn.com
Re: T1 Hub?
hi
As per you requirement its not possible to get 3 T1s speed (3 * 1544K) with 2 wic cards/port installed.
Those cards or ports will be supporting the max speed of 2048K with each E1 or 1544K with each T1.
regds
Community Member
Re: T1 Hub?
Thanks for your reply.
Speed was never the issue, I just wondered if there is a product available to run multiple T1 lines to a single interface the same way you run multiple ethernet lines to a single interface using a hub.
I'm linking 2 networks over these 2 T1's, they will be in the same subnet
Dale
248
