Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
T1 simulator and bandwidth restrictor
I currently house a database and Web server at my site for one of my clients. My client is considering moving the database to their location while leaving the Web Server at my site. Is there any way for me to simulate a T1 either between two of my routers or over my 100MB LAN in an effort to restrict bandwidth to the two servers. I guess it would be sort of like QOS in reverse whereby I am wanting to set a maximum bandwith to guarantee.
1 REPLY
Silver
Re: T1 simulator and bandwidth restrictor
You can use CAR on your FE interface to throttle this down.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios111/cc111/car.htm
The newer way to do this is using a policer "policy-map" with a rate limiter.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t8/ftpolenh.htm
This will do your BW allocation down to what rate you would like but if you are looking for a good test, the above does not account for serialization delay, PPP or HDLC framing issues, etc, you might go with Back to back serials between routers. In this way you can go much slower with your speeds using "clockrate" and better symulate end to end latency as well as BW issues.
Hope this helps,
Don
105
