11-06-2003 07:07 AM - edited 03-02-2019 11:31 AM
Is the 3640 unable to support T3 speed? Is that why the T3 module for 3600's are not supported in the 3640? I'm not trying to push T3 speeds over the WAN port, but would like to concentrate multiple Frame Relay (T1) connections. I would like to know if there are other alternatives I could use to, such as media converter that will go from RG-59 to HSSI.
TIA
11-06-2003 07:26 AM
there is an earlier thread here which I think deals with the same issue, you might want to check it out:
GP
11-06-2003 11:53 AM
A 2621 can do ~40Mbps with full-sized packets. A 3640 should be able to do significantly more. It may not be able to competely saturate a T3 bi-directionally (~90Mbps total), but you certainly shouldn't have any problem aggregating some T1's from a bandwidth perspective.
